Has anybody put an SRT8 rear end into their Se? Also can the Brembo brakes from SRT8 be put on the SE? I have some doner parts from buddy and would like to use if possible. Thanks for the help!!!!
I'm courious about the figment of Brembos as well. Not related to wheel clearance but actual mount spacing.
Are SE steering knuckles different then r/t or S r/t knuckles?
I would check and make sure your wheels will fit with the callipers. I know that people look for spares for SRTs and only certain ones will fit. Might talk with S/S dodge, he does alot of SE mods.
The Brembos need a lot of parts to fit a R/T, would be the same on a SE. Knuckles are completly different.
Some people have been able to get 18s over the Brembos, but for the most part you need at least the 20 inch SRT wheels or custom 2 piece wheels.
The rear end can fit, but you need a driveshaft or at least the back half of the driveshaft if it is a 08 or below SRT. You will also need the axles and wheel hubs as well.
Mikey,
Thanks for the info above but just to clarify and another question.
Are the SE & r/t knuckles the same?
Do all 3 cars use the same ball joints?
Thanks.
-Scott
