1 - 2 of 2 Posts
I own a 2009 Challenger SRT8. As of recently, I have had a TON of issues with it. At about 35k the transmission had to be rebuilt and when I had it done, the transmission rebuild shop put an "upgraded shift kit" in it. About 6 months later the car died and unfortunately it sat dead for about two months before I could get a new battery for it. When I finally got to put a new one in, I would drive and it would lose power and shut off. I then realized that the alternator had to be replaced. Soon after replacing the alternator, I had the ABS, check engine, emergency brake light, traction control, and ESP/ BAS warning lights. I used my OBDII reader and had the following codes:
-P0501: Vehicle Speed Sensor A Range/ Performance
-U1412: Implausible vehicle speed signal received
-U1409: Implausible left front wheel speed signal received
-U140C: Implausible right rear wheel speed signal received
-U140A: Implausible right front wheel speed signal received
-U140B: Implausible left rear wheel speed signal received
-U1418: Implausible right wheel distance signal received
-U1417: Implausible left wheel distance signal received
-C121A: Steering angle sensor not initialized
-C2204: Dynamic Sensor Internal
-C2200: Anti-lock brake module Internal
-C102B: Right rear speed sensor circuit
-C1020: Left rear wheal speed sensor circuit
-C1015: Right front wheel speed sensor circuit
-C100A: Left front wheel speed sensor circuit
Additionally, when I shift the vehicle into gear it is jumping forward (or backwards) depending if I put it in drive or reverse. The last time I drove it, the speedometer stopped working and sometimes the vehicle would only left me go about 20 mph. I would have to pull over and turn it off and on multiple times before it would start to work again. I don't know what to do at this time and really need help. I think that the ABS module and the computer might have died but i want to see what everyone thinks. Anything helps and I really appreciate any input!
Yeah, it sounds like ABS module is toast. BTW you can use the online chilton's manual to help you diagnose if it is bad or not.
1 - 2 of 2 Posts
