1 - 2 of 2 Posts
Hi...I have the factory satellite/blue tooth radio and I am changing out all of the speakers and adding an amp...but I need to know a couple of things...I have to connect a trigger line for the amp but don't know which part of the factory harness at the radio connection would be the correct wire to use for the trigger...also I am putting in a 2 channel amp and have to figure which wires from the factory harness that fits into the radio should be used to connect the radio unit to the amp...
Any and all help appreciated! thanks
No offense but you seem a bit clueless, are you sure you want to do it your self?
To answer your question, you can get your remote from the ACC fuse in the rear fuse box. You need a LOC to hook the amp up to the stock headunit. The thread stickied at the top tells you what wires are what.
1 - 2 of 2 Posts
