1 - 2 of 2 Posts
Do you guys think 2016 challenger scat pack shocks and struts will fit on 2015 sxt challenger? Found some from a part out but wanting to get some info before purchasing.
Yes, they will fit (and improve the ride quite a bit).
NOTE: If you are referring to the whole strut assembly (damper plus coil spring and strut mount) when you say “strut”, I will add a caveat to my reply: the SP strut assembly will still fit the SXT, but the coil springs of the SP have a much higher spring rate than the SXT’s relatively light front end can handle.
In other words, putting some SP springs on the SXT’s front end will be a slight rise in ride height of the front axle.
But if installing the dampers only (shock and strut bodies) from the SP, then you will be fine and can disregard my NOTE above.
1 - 2 of 2 Posts
