I'm having a local shop install my Baer brake kit with 6 piston calipers on all four corners. They said the brakes felt a little soft and required a lot of pedal travel. They were going to double check the install and bleed them again but also said it may require an upgraded master cylinder with a larger bore.
Anyone run in to this? If so, what is the best master cylinder to go with?
__
__
