🤣🤣My uncle bought a new Dodge truck once and did the first oil early. He is no longer alive.
I purchased the 2011 Challenger in my signature brand new, and I did not do the first oil change early. I am still alive.
The choice is yours; choose wisely!
It’s cheap piece of mind then to change it around 1000 miles the first time.I wasn’t sure if they put special lube in the oil To lubricate all components and I worry about pieces of foreign matter in the oil. Somebody once said nowadays they dyno Different motors on the assembly line at random
the engines are "cold spin" on a test rig to check for any noises, oil pressure is verified. The machine can detect if there's equal compression from all cylinders by measuring crank speed variation referenced by the Crank Position SensorI wasn’t sure if they put special lube in the oil To lubricate all components and I worry about pieces of foreign matter in the oil. Somebody once said nowadays they dyno Different motors on the assembly line at random
Auto manufacturers want me back every few years for a new vehicle. I believe they have an inherent conflict of interest which introduces a bias in their recommended maintenance schedule. They need to bring enough longevity and value so that I buy from them again (and not a different brand), but the vehicle also needs an end of service life to compel me to replace it eventually.If early oil change was required or recommended to protect the engine from failure and FCA from warranty liability, FCA would recommend / require it. They don't, recommendation is 6Kmiles or as indicated by oil life meter. With that said, if you feel better by changing the oil earlier do it, it your prized possession.
unlike GM with the dry-sump C7 'Vette engines (Z51 / Z52 / Z06) that required an oil & filter change after the first 500 miles...there were engines that had oil starvation issues and seized...If early oil change was required or recommended to protect the engine from failure and FCA from warranty liability, FCA would recommend / require it. They don't, recommendation is 6Kmiles or as indicated by oil life meter. With that said, if you feel better by changing the oil earlier do it, it your prized possession.
Hell yeah. I would get the 1st oil change done no later than 1500 miles regardless of what the manual says.Just purchased a 2020 scat pack shaker challenger should I change the oil earlier than the recommended first change? Thanks
Actually, it's been said by several in the know around here, that the break in is more for the rear end gear set.Guys, this is pretty simple if you think about this way; the manufacture has a "500 mile" break in period.
This is because the engine is new and has never had any (zero) full on heat cycles. All the different metals are expanding and contracting- as a unit-- for the first time. Some metals expand at different rates and the "mating" process crates grooves (small shavings) in the different metals.
If you ever have rebuilt and engine, you will always put the same piston back in the same cylinder and the same push rods and rockers together--- because they have worn (metal shavings) together.
Change your oil early. Just because Fruit of the loom says your under ware can last for months doesn't mean you shouldn't change more often.
Does that imply that one should change the diff oil sooner as well?Actually, it's been said by several in the know around here, that the break in is more for the rear end gear set.
Owners just need to be comfortable with what they do to their rides.
That's all that matters.
