1 - 16 of 16 Posts
2020 Dodge Challenger R/T
Just here to say hello. Also i had a question on wheels. I talked to two tire shops and both told me i got the best tires i could get (stock) and recommended not to go for a wider tire. But i want wider tires, maybe 275/40-20s all around? Any advice?
995137
Just here to say hello. Also i had a question on wheels. I talked to two tire shops and both told me i got the best tires i could get (stock) and recommended not to go for a wider tire. But i want wider tires, maybe 275/40-20s all around? Any advice? View attachment 995136 View attachment 995137
275/40's will work best with the scat pack stock rims, I have them on all 4 corners assuming all 4 rims are the same width, If you want wider you will be best off switching to wider rims. Going much wider will require some calculations and/or experimentation as far as spacing the wheels out so you don't have any interference.
The way I look at it, if I have a 9 inch rim wide even if I go a wider tire I am still putting 9 inches of rubber on the street
Here's 275/40R20 Goodyear Eagle Sport A/S on my 9" WP3 wheels.
995146
2020 Scat Pack Shaker 6 spd manual 18 spkrs Harmon Kardon
I smile reading that as it is the reality! Wider too often is for looks...
Of course is for looks but you can’t expect better grip or performance, it’s like eye candy it serves no purpose just purely cosmetics, like a badge lol
Welcome from California ;)
To answer your question we need to know your current tire size and your current rim width as well, i am assuming you have the 245 tires?
2014 SRT Core
Welcome to the forum.
:unsure:You look a little young to be driving that race car.......just sayin (y)
Yeah stock 245. Is the grip even worth the money?
Your rim is 8 inch wide, I personally would go past 255, that’s my personal opinion, for the 275 tire manufacturers suggest no less than 9 inch wide, I am not sure if you will get into problem for running the tire out of manufacture specs, if you want wider tires then get wider rims, once again your rims are 8 inches wide so if you have 245, 255 or 275 you are still only putting 8 inches of rubber on the road so no additional grip, and my personal opinion idk why dodge made those 8 inch wide rims with 245 not enough meat to even for the RTs 5.7L, they should have made the 9 inch 275 as a standard
Discussion Starter #13
I see, thank yall. Ima sit at 245 till the tire needs to be change, than maybe go 275.
1 - 16 of 16 Posts
