It almost sounds like a bad power steering pump, but I know the car has electric steering. Could someone listen to this recording and give their opinion. I would also like to know if anyone else's SXT sounds like a diesel on a cold start. I had a previous post about an idling issue and the dealer said it was "normal". Now my car has been at the dealer for 2 days and they just left me a message stating that the new noise that wasn't there before is "normal". It must be a running joke at this dealership or something. Before I drive out of town to find another dealer, I hope I can sound somewhat knowledgeable about this noise before I escalate this. I wish the "Whine & Shake" option was on the window sticker before I bought this car.
I uploaded the audio file to here since I couldn't attach it. h**ps://instaud.io/1reV
I can't post links because I'm a newbie, so just add the the missing T's.
My car has made that same noise since the day I bought it new. Only on cold starts and it's louder the colder it is outside. Maybe you're only noticing it now because it's colder outside.
My car makes that noise when the idle drops on a cold start. It's not as pronounced as yours, but it's the same. A Guy
Reactions: Texredner
2013 Challenger SXT
Sounds like maybe water pump or alternator, of course if this was my car I would just remove the belt and start it and see if the noise was gone and spin each part by hand , I guess you could also have a bad idler pulley as well. Car sounds normal except for that loud whine, like a dry bearing sound.
The ticking sounds like cold fuel injector rails; not sure on the whine. Both my '14 & '16 Challenger SXTs have the same start-up noise when 45 degrees or colder. Problem goes away after a few minutes of driving.
We've had 3 other 3.6L Pentastars (2 Jeeps & a Chry 200) that did not have this issue.
Discussion Starter · #7 ·
Thanks for the responses. It sounds like the consensus is that it's normal. I will let it go for now and hope that if it is indeed a part, that it fails before the warranty expires.
If I let my car sit for a few days, I'll hear ticking for a couple of seconds upon start-up.
My 2013 SXT had a loud whine when started up below freezing. The sound would go away soon. I just think this is all a characteristic of the 3.6 engine.
