2010 srt8 challenger 6 speed
so I finally finished up the install and got the bottle filled yesterday. Tested everything and it all works perfect except for the rocker switch for the bottle opener. I tested the circuit and im positive its a bad switch. I emailed nitrous outlet to see about getting it replaced and haven't heard back. If I don't hear from them today ill just buy one. If anyone is looking to get a bottle filled around Dayton Ohio I would go to complete auto repair in Germantown. Tony is a racer he also owns kilkar dragway. He is the cheapest around here at 6.50 a pound. I said I'd post some pictures so here they are. I'm think it really turned out good. I put the window switch in the center glove box. Its kinda hard to mess with but once its set up what more do you really have to do.
999953
999954
999955
999956
Dyno numbers?
Just got the email tune today haven't put it in the car yet. I'm not sure when I'll get to put it on the dyno spent WAY more then I wanted to lol. With a 75 shot I'm not sure it will be a huge wow factor but maybe. 75 extra horses is nothing to sneeze at. When I eventually go to a 125 shot then I bet the wow kicks in.
2015 SRT 392
Congratulations on both you install and your setup/installation skills! Everything is nicely run and looks like a Professional shop did it (that's supposed to be a compliment :) )!
I'm looking forward to hearing your review once you get a chance to try it out.
Discussion Starter · #5 ·
Hey thanks. I am real happy with the way it turned out. I just took my time. My son said if he didn't know it didn't come with nitrous he'd say it was factory. I can't wait to try it out. I just noticed the pics of the bottle were when I was getting placement so ill post some better pics. I'll post some more of the wire harness also. I do kinda have an advantage since I'm an electrician. Plan your work and work your plan works almost everytime 😆
Well ? Still have the NOS going ? Also how the shifting feel with the Manual trans any issues with clutching ?
Discussion Starter · #9 ·
Yep still have it. I never even filled the bottle this year. Seems like I've just been so busy with life stuff I don't even have much time to have any fun. As far as the shifting with the manual it's fine. I installed a window switch so the nitrous shuts off unless it's at full throttle and over 3000 rpms. So when I let off to switch gears the nitrous shuts down till I'm back on the gas and over 3000. I also have it set up to shut off at 6400rpms. My shift light is at 6400 and my rpm shut down is also 6400. The last thing you want is cylinders full of nitrous hitting with not enough air and fuel. You can definitely feel the nitrous hit and its fun for sure. I'm glad I did it, it was a cheap way to get horsepower. I'd like to try a 150 shot, might do it this year before it gets to cold. I hear a 150 shot is about all you want to do with a stock bottom end. My car does really well with a 100 shot I don't have any short term knock at all the tune seems really good. As long as you have all the safeties in place and a good set up I feel really confident in using it. Plus when you hit that purge it can get you out of some races cause they are skeptical about what you have. I can try to answer any questions on the set up as far as wiring and things needed.
