2012 Challenger RT
Where is the easiest spot to tap the fuel line for a wet kit? Will the hardware come with the kit or need to modify it?
If you get a wet kit for a hemi it should come with a fuel rail fitting to tap for fuel. It goes between the fuel supply hose and the fuel rail itself. Most are just press on like the hose itself. See the part stamped NX:
Yes.
You can see the part number in the pic I believe but here’s a link.
2013 Core
Any good kit will come with the tap. You'll have to invest a few dollars in the tool to disconnect the fuel line from the rail.
The tool is avaliable at any auto parts store.
Sent from my SM-G965U using Tapatalk
2012 Challenger RT
Yes.
Thanks!
2012 Challenger RT
  • Yes.
    Another question, does the adapter you listed come with the side adapter to screw the nitrous fuel line to or is that a separate part?? I see you added the pressure gauge to it so did it come with the adapter to screw the gauge into and then hook the fuel line or did you add the gauge because you needed the adapter anyway? Thanks in advance just making sure I have all the part at hand when I install.
