1 - 4 of 4 Posts
2021 Redeye
A bit more clarification would be helpful :) I'm not sure what the View attachment 1063192 is because it comes back;
Oops! We ran into some problems.
The requested page could not be found.
How do you know there are no DTC's? With limp mode, there should be a code that's stored that's severe enough to put the engine into limp mode. Until that's corrected, you are stuck with limp mode.
Can be as simple as an unmetered amount of air getting to the intake/throttle body.
Discussion Starter · #4 ·
No Check Engine Light but....when I pulled the codes!!!
P0501 VEHICLE SPEED SENSOR 1 PERFORMANCE
U1409 IMPLAUSIBLE LEFT FRONT WHEEL SPEED SIGNAL RECEIVED
U140A IMPLAUSIBLE RIGHT FRONT WHEEL SPEED SIGNAL RECEIVED
U140B IMPLAUSIBLE LEFT REAR WHEEL SPEED SIGNAL RECEIVED
U140C IMPLAUSIBLE RIGHT REAR WHEEL SPEED SIGNAL RECEIVED
So where is speed sensor 1???
I have NAG1 transmission....
Thank you for your time,
MAKeller
Personal computer Cloud Font Gas Computer
1 - 4 of 4 Posts
