1 - 2 of 2 Posts
For the new non-MDS lifters, you can rotate the lifters 180 degrees in the yoke, right? I ordered some from Dodge and they came a little mixed up in the boxes, but they look identical on each side.
Would not count on the lifters being orientation neutral. For example if the lifter body has a groove around it and an oil hole in the groove this hole probably (but this is not "official") goes 180 degrees away from the oil hole that feeds oil into the lifter bore.
But you need to be 100% sure the proper orientation if there is one.
1 - 2 of 2 Posts
