2010 SRT. I am planning to install a wide band afr gauge. My concern is simple, Where do I install the O2 sensor. I understand you want the sensor before the cats. Between the SRT stock header and the stock cat there is maybe a 3" pipe. This is where the stock O2 sensor is. I don't believe there is enough room for two sensors. Anybody have a solution to this?
There is enough room there. That is where I have my wideband O2 sensor installed.
Discussion Starter · #4 ·
Thanks Sublime. It just looks tight. I mean, that is what I was going to do, just fishing to see if there were any other options.
The other option is to use LC-1 and use the existing O2 sensor hole for the wideband sensor and then hookup the narrowband signal from LC-1 to the stock O2 harness.
