1 - 4 of 4 Posts
OBD II port mystery - Problem solved!
Got bit of a mystery on my hands:confused:. Installed the Tazer double bypass with the plan of using the original OBD II port for other devices. Looked under the dash and surprise! No OBD port just a hole in the sheet metal where the port should be. Haven't pulled any trim panels to look elsewhere but can't see them putting it anywhere without easy access. It's a 2017 R/T plus Shaker. Has anyone else run into this issue? Any help would be greatly appreciated.
Sometimes they pop out of the bracket.
Pulled the trim panel around the pedals today. Sure enough the OBD II plug was tucked up against part of the rest of the harness. Looks like somebody at Brampton probably overlooked it.
Thanks again Ken for helping me solve this:thumbsup:
1 - 4 of 4 Posts
