Dear all ,
Slowly putting my engine back to together , just waiting for a Stretch Gauge to arrive (ARP) so I can torque up and measure stretch on those arp 8740 bolts! Question !!..... I am putting the heads back on, using OEM head bolts which came from the kit Arrington sent me
I do have torque values and the procedure but it does not say to lubricate the bolt thread and head of the bolt.
,, do they go back in dry ? I would of thought oil would have to be used if the are dry, friction sets in ?? good advice would be much appreciated I`m sure there`s guys out there have changed head bolts
Car in question 2014 SRT8 392 6.4L
Service manual does not say to apply oil. I have always chased the block threads and they applied a little engine oil to the bolt...that is what my highschool shop teacher taught us.
Yes I think you are right, I will clean and chase out thread and lightly oil the threads, strange they do not say about it !!
Some torque specs are listed as lubricated, or unlubricated. Old school always said oil on threads, and under bolt head. You will definitely get different readings between the two methods. No instructions with the kit? Usually advising to torque in 3 segments, etc. A Guy
make sure you get a dial guage for your ratchet.. factory bolts are torque to yield.. if i remember right there is 2 different torque seqences. i for get the numbers but at the end it is something like a PLUS 90 degrees or PLUS 45 degrees ect.
that is why i went with arp.. little more but reusable and torque and done.. no need for the additional guages to measure with
would always stud the upper and lower end when rebuilding, would not use bolts
Luke
Yes mind was already made up bought ARP Bolts not using OEM bolts, thanks us1champ and Luke from Steve White parts
did not release you can use studs anyhow going to use the arp should be fine!
I used arp head bolts and no issues at all in mine.
