101 - 120 of 182 Posts
Reset the record! (5.7 auto N/A Super Stock)
Friday, November 19th 11:31am.
Atco Raceway (Atco, NJ).
DA -1100
Race weight 3700 (with driver)
Same mods as last time...just tweaked the tune (thanks A.J./hemituner), and added a splash of 100 octane.
2010 SRT8
New PB V6 Challenger 14.82 @ 92.36mph
Friday 11/19/2010
ATCO RACEWAY
ATCO, NJ
DA: -1100
[/IMG]
2009 Challenger R/T Auto
R/T Auto Super Stock Class
Mods:
Kooks LT Headers with High Flow-Cats and Mid-Pipe
MBRP Cat Back Exhaust
Vararam Test Air Intake
Predator
Jet 180° Thermostat
93 Octane
Nitto NT05R’s 275/40/17
4040 lbs w/ driver: Seats removed
Run Info:
Jan. 08, 2011
11:51 AM
Dallas Raceway Crandall, TX
60’ = 1.771
1/8 = 7.910 @ 87.97
1/4 = 12.359 @ 107.66
DA = -436
CAR DETAILS
  • 2010 Challenger SRT8
  • Automatic
  • N/A modified
  • 93 octane pump unleaded
  • Magnaflow Competition Exhaust
  • Hankook V12 Tires
  • 180 T-Stat
  • Modern Muscle CnC 85mm Ported Throttle Body
  • C&L Intake
  • Inertia Spartan Camshaft
  • Inertia Performance Heads
  • Ported Intake Manifold
  • Stack Performance Phenolic Spacers
  • CMR tuned
  • Stock rear gearing
  • No weight reduction - 4190 weigh in (w/o driver)
RUN DETAILS
San Antonio Raceway (Texas) elevation 553ft
01/28/2011 10:59 PM
Driver/Owner: Ray
Racing procedure: No stall, ESP Off, Trans in Manual mode (started in 1st gear and let trans shift itself through each gear), rear tire pressure at 31 psi.
A few things learned: I actually got better traction from not stalling the car vs. stalling the car at 1500-1800 rpm. The stalling at 1500-1800 rpm might be better for drag slicks but for stock tires, not so much.
Reaction: 0.4046
0-60 Foot ET: 1.9624
1/4 Mile ET: 12.60
1/4 Mile MPH:
112.11
1/8 Mile ET: 8.1842
1/8 Mile MPH:
88.43
Temperature F:
56.8deg
Density Altitude (DA):
484ft
Timeslip Scan:
Car #56 - 2010 Challenger SRT8 - Mods above and sig
Car #58 - Pontiac G8 Sedan - Tuned
CAR DETAILS
  • Automatic
  • N/A modified
  • Hankook V12 Tires
  • 180 T-Stat
  • C&L Intake
  • CMR tuned
RUN DETAILS
01/28/2011 10:59 PM
Driver/Owner: Ray
Reaction: 0.4046
1/4 Mile ET: 12.60
1/4 Mile MPH:
112.11
1/8 Mile ET: 8.1842
1/8 Mile MPH:
88.43
Temperature F:
56.8deg
484ft
Timeslip Scan:
Great times. SAR is always a tricky track and typically slower than the Borth Texas tracks. It is a fun place though. I am fifteen minutes from the track if you ever need anything or want to try my drag radials.
Take care,
Mike
ran my d/a and came up with 11.6 and 11.8 supercharged
Discussion Starter #107
I want to apologize to Evertone for this, as I have fallen way behind...between personal issues and sickness/deaths in the family, I have not been on here in a long time. I am in the process of updating the list, and will be using a new format....this should simplify things.
It's all good! Thanks for letting us know :)
R/T Auto Power Adder Class
Mods:
K&N CAI
Predator
Jet 180° Thermostat
100 Shot of Nitrous
93 Octane
4070 lbs w/ driver: Seats removed
Run Info:
Feb. 12, 2011
12:06 PM
60’ = 1.768
1/8 = 7.512 @ 93.24
1/4 = 11.721 @ 116.54
DA = -191
forgot to include the nitrous in the mods on that run, but nice run :)
Very nice run! :) Stock axles still? What is your launch technique on the M&H's?
Me? No, I changed them out for Paramount axles long before I put drag radials on.
With the stock clutch it was 4500-5200 rpm give or take and letting the clutch out quickly, but not dumping it or slipping too much. Best launches came when the engine got dragged down to around 4K.
Spec clutch... still working on that, it is trickier to launch than the stock clutch especially on non-ideal track conditions.
Mods:
K&N CAI
Predator
Jet 180° Thermostat
125 Shot of Nitrous
93 Octane
4090 lbs w/ driver: Seats removed
Run Info:
Mar. 6, 2011
4:21 PM
60’ = 1.775
1/8 = 7.498 @ 92.74
1/4 = 11.687 @ 116.85
DA = 493
2013 Calleenger
Firday Night my first 1/4 mile run
OK so here it is last runs on top, just kept gettin better, as the whole drag race thing was pinging arround in my brain, (role up the windows... both of them... turn on lights...it was at night... after 5 runs I noticed the track had changed and I was getting way too much traction so I turned off the traction...and as I shut off the engine to keep it cool as I lined up to run... keep turning of the traction...helmet full face required here too tight...Damn let's race.... now with a 15 mph head wind best times were
13.6171 @ 102.71 mph
13.6499 @ 102.98 mph
13.7872 @ 101.36 mph
13.8642 @ 102.25 mph
13.8528 @ 96.16 mph
14.1641 @ 92.80 mph
14.2079 @ 100.43 mph
14.2319 @ 101.83 mph
14.3380 @ 101.36 mph
14.3469 @ 99.97 mph
At the start of the race the track was slippery about 500 feet. I needed the traction on. As the track got sticky I started getting wheelhop. I was even trying not to burn out too much traction wheel hop.
Finaly figured to burn out start in the wet... burn clean the tires... worked best I got good launch little spin and a little wheel hop once or twice more.
I had a great time. Used a set of stock tires Goodyears on the back I saved from the originals from factory. If you have not done this yet you need to! WHAT A BALL !
Here is my entry:
- Super Stock
- 2009 R/T Classic
- 5.7L VVT engine
- 6 speed trans
- 180 T-stat
- Voliant CAI
- Diablo Running 93 Octane
- NO Other mods.
- Stock Factory Exhaust
- Factory Goodyear radials @ 23lbs psi
- CoastalPlainsDragway, Jacksonville, North Carolina
- Date of run 4/15/2011
- Time of run 9:43pm
- DA 192
- 2.1159 60 ft time
- 1/8 Mile 8.8331 @ 81.93
- 1/4 Mile [email protected] 102.71
2010 Bone stock Challenger Srt8 6.1 auto with all season tires, just like it came off the showroom floor. 12.852 at 109.11.:thumbsup:
bone stock IE 392 with street 20" F-1's
R/t .075
60' 2.059
1/8th 8.406
1/4 12.911
110.33MPH
track conditions 89degrees outside temp, 80% humitity
CAR DETAILS
  • Automatic
  • Power Adder Class
  • Kenne Bell 2.8H at 9psi
  • Stock 6.1 motor
  • 275/40/20 P-Zero's on bonspeed 20x10 "Pony" wheels
  • Mopar Cat-back exhaust
  • 180 T-Stat
  • Stock T-Body
  • Kenne Bell "caned" tune
  • Kenne Bell Boost-a-Pump
  • No weight reduction (348# driver, around 1/2 tank of fuel)
RUN DETAILS
Beech Bend Raceway Park (Bowling Green, Ky.) 529 feet above sea level
ChallengerFest2
04/30/2011 3:35 PM
Driver/Owner: Jason Maas
Note: This was the best (and one of the last) of 29 runs I made that day starting about 10:45 AM
0-60 Foot ET: 1.945
1/8 Mile ET: 8.068
1/8 Mile MPH: 90.09
1000 Foot ET: 10.404
1/4 Mile ET: 12.355
1/4 Mile MPH: 115.33
Temperature F: 79.0
Density Altitude (DA): 2088 feet
Relative Density: 94.03 %
Timeslip Scan:
*The date on the timeslip is wrong, as was all the slips that day at CF2*
Bone stock 2011 Challenger Srt8
Stock F1's
392 Hemi
Auto
I am car 397. I ran a 12.65 at 110.44 mph
I put the info into the dragtimes site for DA and corrected time and got this
Correct your ET and MPH using the DA (Beta Testing)
Density Altitude: 1086
Stock and Mildly Modified Naturally Aspirated Engines
12.509 @ 111.688 MPH
So I guess a corrected time would of been 12.5
