Have heard alot about using a an oil catch can? and it being alot better for the engine? Is there a certain hp or model that it is used on?
Thanks for any info with this matter.
Chris.
From what I have read on this forum, its a must. I installed one on my 2019 Scat Pack w/Shaker. It wasn't to bad. I had to buy some extra parts that my kit missed out on. It was guess the part needed and custom cut my hoses. I watched several y-tube videos and bought some half-inch brass barbs, you need two. Since mine is a Shaker, it is mounted a little lower ,but it worked out okay. I drove it yesterday with it on for the first time. It didn't fall off or hoses come loose and blow oil everywhere, so I count it as win !
I think I should buy a couple of those OEM rubber/plastic connectors that connects to the air intake, that you put the brass barb into and connect your half inch hose to. Cause I had to move the hose around to various routes, just to relieve stress on the 'elbow' ( lack of a better term) connector on the air intake tube. That's where having extra hose for custom 'cut & fit' comes in handy. mine connects on the top of that big air intake tube, not the side. Side would have been better for me. but it can't because of the Shaker mounting bracket.
Yeah, install a catch can. The original plastic factory hose, has a oil residue inside it from the first 560 miles on the car. So it must blow oil.
We'll see what Mr. Catch Can does now.
have a good one !
