1 - 20 of 26 Posts
I'm getting the "oil change required" notification on my evic after only about 4k miles and 5 months. This happened prior to the last oil change as well. The oil level might be slightly low but it doesn't seem worn. I use royal purple synth and srt filter. Any reason for me to be concerned? Thanks!
Reactions: spoolboy
The 6 months is only for 392 and SRT, it's still max 1 year for 5.7L.
Don’t go with the notification rather mileage and driving habits. Since you’re using a good filter with synthetic I’d do it every 8K miles but not exceed a year. JMO
Hmmm?
Reactions: spoolboy
Thanks for this Info!. I thought synthetic oil is only for 6000 kms to a max of 8000 kms or 6 months whichever comes first. (I follow this with my Hyundai genesis coupe).
I didn't knew it could exceed more than 10,000 kms in a bnew car! especially in the challengers.
Just posting what the owners manual said. A Guy
Reactions: spoolboy
Thanks all for the replies. Sounds like the notification is a little early, but based on approaching the 6 month interval its about time for a change anyhow.
On a related note, I'm thinking of going to the dealership for the 30k service since I need to have a couple recall issues addressed anyway. If I bring the SRT filter and Royal Purple oil will they cooperate or try to force me to use their oil and filter? I purchased an extended warranty from the dealership when I bought the car used but can't tell if that would be precluded in the terms...
What does the 30K mile service include?
They can’t force you to use their oil but it’ll be documented. I wouldn’t do it specifically since you have extended warranty.
Service manual says different...LOL this reminds me of the 345 CI...348 CI...no 345 CI Dodge scribblings. BTW SRT is 6 month.
In the '16 Owners manual, both 3.6 and 5.7s are
10K mi / 12 mos max or 350 hrs run time
SRT engines are 6K mi / 6 mos max 6.2 SC or 6.4
Discussion Starter #13
Technically I guess its a 32k service but aside from oil change the major items are change spark plugs and possibly change manual transmission fluid.
Ok I see. You have 2012 RT. Yeah the spark plugs need to be replaced at 30k miles on the 2012s. Not sure about the transmission oil. What does the manual say?
Have you changed the cabin air filter yet?
Discussion Starter #15
Thanks. The manual says manual transmission fluid should be changed if driving in hot weather or stop and go traffic, the latter is more applicable to me so I thought I may as well do it. I also need to change the cabin air filter and engine air filter. I guess my normal shop should be able to do those things instead of the dealer unless there's something unusual about the plugs or transmission service?
What year?
As Hal said, it's one year now and has been for several years far as I know.
What year?
FYI - the info I posted from the service manual was for 2015 models. I think A Guy might have grabbed his info from the 2016 owners manual as that is the year Challenger he owns.
The 2015 owners manual shows 12 months for non-6.4 engines.
Discussion Starter #18 (Edited)
This is for a 2012 5.7 (not sure why my sig isn't showing up reliably). 2012 owners manual says interval should not exceed 6 months or 8k miles. It looks just like the attachment A Guy posted on the previous page.
This from the 2016 OM ..
What year?
OP has a 2012 R/T
1 - 20 of 26 Posts
