1 - 4 of 4 Posts
Ignition on - (don't start engine...foot off brake pedal/ automatics...don't press clutch pedal on 6-speed) press accelerator completely to the floor and release 3x within 10 seconds.
Shut off ignition.
To check if reset (no chime / no message) repeat the ignition on (engine off) and wait ~ 5-8 seconds. If no chime/message you're set.
If you get the message / chime, repeat the process and re-check.
Turn ignition on, but without starting engine, press gas pedal to floor three times, turn ignition off.
1 - 4 of 4 Posts
