1 - 19 of 19 Posts
Welcome to Challengertalk ;) You want 5w-20 for your 3.6L
Reactions: Wizard of Iz
2011 gwe srt
20w50 is usually a summer oil for hard working motors like diesels that are built with larger tolerances. We used to use it even in muscle car motors that were getting a bit loose but todays motors have much tighter tolerances and oil that thick just doesnt flow good enough to carry off heat. Most new cars use a 0w or 5w oil for that reason.
They still make 20W-50? That is waaay too thick to put in a modern engine.
Not necessarily. It depends upon the engine. I believe some Ferrar engines require 20w-50 (or possibly 10w-60) and likewise some BMW engines -- at least those from some years ago -- require 10w-60 oil. I recall considering a BMW M3 coupe and its 6-cylinder engine with "solid" lifter valve train required a similar oil.
But 20w-50, 10w-60, 15w-50, even 5w-50 oils should only be used in engines for which the automaker approves.
As an aside my Porsche 996 Turbo could use 0w-40, 5w-40, or even 5w-50 oil the last two oils only if temperatures were above -25C. At some point I switched to using 5w-50 oil in my Turbo. But the hot idle oil pressure did not go up. The oil was not "thicker" it just had better HTHS numbers compared to the 0w-40 oil.
Gt 500 uses 15w 50 FYI.
Is that a factory recommended oil? If so wow!
BTW, some years ago when 15w-50 came up because it was an oil "recommended" in the owners manual of a car I owned at the time. However, the owners manual was terribly out of date, the automaker never bothered to up date it. Instead the automaker provided its dealer network with a list of a approved oils none of which included any 15w-50 oil.
I looked into 15w-50 oil and it is not a very good oil. It suffers from viscosity degradation among other things.
Talked to a guy who insisted on running 15w-50 in his air cooled car engine instead of the 0w-40 oil the factory called for. He admitted gas mileage with 15w-50 was not as good as it had been with 0w-40 oil and his track lap times were a bit lower also, but even after admitting this he still insisted on running 15w-50 oil.
If I owned a GT 500 and if the factory called for 15w-50 oil I'd use it but I wouldn't like it.
I have a Question, My 5.7L uses 5W 20 would it be okay to use the same 0W 20 that the 6.4L use? I no longer have MDS or VVT due to a cam swap.
What do you hope to gain by switching from the recommended 5w-20 oil to the 0w-20 oil?
While I am a "fan" of 0w-XX oil as the "0w" offers "better" cold start protection if the factory recommends 5w-20 oil that's what I'd stay with. It is not like cold start was not factored into the factory's oil recommendation.
If 0w-20 is an alternative oil and recognized by the factory as such then you can choose to use that oil if you want.
I just thought the full synthetic would be better. I only change my oil once a year, before I park it for the winter. Cold staring is not a concern I have
The 5W-20 should have MS-6395 as recommended so any synthetic that meets MS-6395 would be fine.
If the factory has a synthetic oil on its list of oils approved for use in your 5.7l engine then if you want to run a synthetic oil from this list do so.
There was someone here that had a 5.7L M6 (no MDS) that was ticking and she said that Dodge said she could run the same 6.4L 0W-40 to help quiet the tick.
5w20 synthetic is what I ran for years on my 6 speed 16' RT. My last oil change I put 0w40. Not a difference in the slightest and it's actually recommended on some 6 speeds
1 - 19 of 19 Posts
