I have been thinking about removing the factory two-piece drive shaft and replaceing it with an aluminum one-piece unit from G-Force engineering. How much problem is this to accomplish? It was simple in the 70's when I had several Mopars but now I bet removing the OEM shaft is more involved and an X pipe exhaust will make snaking it into position harder. Once it's in, what have I gained? Quicker to react to throttle commands, less parasitic HP loss, smother feel when driving at part throttle?
Now when I part throttle stab it I feel a roughness or jerkiness like all the joints are loading up tight then rebounding, getting loose and tightening up again. I don't like that feeling. Tell me your feelings on this mod if you've done it and say if was it worth the money for you please.
