1 - 18 of 18 Posts
Hi
I have a 2019 challenger sxt, and i dont have the option to turn the DRL(orange) on on my screen
is there another way turn them on?
mmm, hopefully someone can shed some light on this question....
sorry couldnt help it.
Assuming not a Canadian issue as you said turn them on
Press the “Settings” button on the bottom bar, or press the “Apps” button, then press the “Settings” button on the touchscreen to display the menu setting screen> Lights
989267
Be sure to have the engine on, headlights off, and parking brake off when you check to see they are working. You have which head unit 7" or 8.4"?
Canadian car would have them on and be unable to turn them off.
But I've seen some Canadian spec say "Headlight DRL" so was thinking some CA cars might not use the orange lights at all and this could be one of them.
2016 R/T Scat Pack
I was under the impression that meant the Orange Halos stayed on 24/7.
Have you seen otherwise?
I dont have that option on my screen
Mine is 7
Saudi, Middle East
Check your build sheet here and see in the equipment if it says anything about the daytime running lights or DRL and the market specifications country, whether USA or Canada or other.
COMPLETE VIN
ALL CAPS
Do you have the Settings button?
989332
And when pressed, the down arrow above it? If you press the down arrow, no Lights settings?
Hi
You should be able to get it to show up on the uconnect screen using AlfaOBD and a bluetooth OBD interface like OBDlink MX or MX+.
AlfaOBD software is available for PC or android. The free version only works in 15 min intervals. Basically it lets you change the BCM configurations.
989334
You could also do it through a Tazer which will give you an option for the DRL.
989335
In both cases you will need to get a security bypass since you have a 2019.
Did you look up your build sheet?
With headlight switch off in the daytime are any lights lit up in front?
Discussion Starter #16
Where i can find the build sheet?
- when i turn off the lights,all 4 front lights stays on but brighter....
Discussion Starter #17
How to get the security bypass
See Slidd's post above
Put your full VIN# in the spaces to get the Build Sheet and Window Stickers, and post them here
1 - 18 of 18 Posts
