1 - 20 of 27 Posts
Make sure the parking brake is set to off when you check to see if it worked ;)
Yeah us M6 guys have to be on flat lands...the only perk of living in IL I guess...to check. Although I don't think I ever use the PB on any of my automatic vehicles.
Well just tried it and of course no option on the 5.0 radio.....dam I need to upgrade to the 8.4
Should be a controls button, then settings, lights and should be there.
I'm stumped, should be there, unless the radio was swapped with Canadian version, they have no ability to change DRL settings.
That’s picture is all I have...no option to change to amber color.
So you get that picture and click to turn them ON and what happens? If the parking brake is OFF the ambers should come on. If not could be a false signal from the parking brake.
If it was a faulty PB signal, he should see a light on the dash as well. Do the autos have to be in gear for the DRL to kick on? On my 2013 jeep, putting the car in park or neutral will cause them to turn off.
A8 DRL should be on any gear, only parking brake will turn them off.
The wording is the same for 8.4, except on the 8.4 you put a check mark.
Car running, in park, parking brake off, you should have amber DRLs with the ON button selected
Turn the auto headlights off or move car out in the sun where headlights won't automatically come on, the DRL won't come on if the headlights are on.
1 - 20 of 27 Posts
