1 - 3 of 3 Posts
So quick question..I had replaced my original stock wheels on my 2019 Challenger RT. When the put in the new wheels turns out they used adapters. Would their be a problem if I try to put the stock wheels back on. Like will the adapters come off no problem. Or will I have to do some modification?
Assuming they just added hub centric adapters, or lug spacing adapters, and they will just come right off. There should be no modifications to your car
It is possible that they used a type of bolt on adapter that requires shorter studs, or stud removal. If so, you may need studs replaced. Do you have any pictures of the hub with the wheel off?
1 - 3 of 3 Posts
