1 - 1 of 1 Posts
I recently replaced the heads on my 2010 Dodge Challenger RT and after I replace them the vehicle would not start and I hooked up a diagnostic machine and it showed me to code p0118 and p0113 what is the ambient air sensor and the other one is a coolant temp sensor I replace both sensors but the codes keep coming back it won't let me delete them in the car won't start. thinking I might have a fuse or relay problem I started swapping fuses but the car still didn't start and when I hooked up the diagnostic machine it showed me a p0123 code which is a throttle position sensor. To my knowledge you have to replace the throttle body there is no TPS sensor. everything was working on the car before I change the heads and I did not everything was working on the car before I change the heads and I did not remove the throttle body from the intake can anyone help me figure out why my car won't start
1 - 1 of 1 Posts
