1 - 1 of 1 Posts
Hello, I have a 2010 RT 5.7 6 speed, I am having a no start or crank issue. The code it showed was P0928-BTSI CONTROL CIRCUIT My issue is I have a 6 speed and this code seems to be for a automatic? Do I pretend the issue for the code is the clutch safety switch instead? I have two plugs on the trans. I assume one is for back up lights, do not know the other, If I am on the right track were does this circuit begin in the WIN module? Looking with my meter it seems to come out of WIN module to safety switch, then to ECM and finally to the TIPM module to fire the crank relay? Is this the correct? Are there any models the circuit goes through, I have nothing coming out of the WIN, I even check for a ground signal and nothing. Is there something in this circuit I am missing, and also is it 12 volts? Or is that code something totally different? I have searched and searched for wire diagrams and it has been a issue finding anything for the six speed.
Any thought or help would be appreciated.
Thanks Lane
1 - 1 of 1 Posts
