Can't take credit for this mod, but I like it enough to do it this weekend :)
Wow... love it! I was hoping to do something like this, maybe in Go Mango... ;) More details please, if you would share how you did it. I'm not very artistic. Any help would be appreciated.
I was an auto body man years ago, and I can give a home brewed suggestion: paint the each cap flat black, let it dry well. Flat always dries faster. Then mask off the outside of the area you wanna paint red with 4 pieces of masking tape. When yer done, run one piece (cut to perhaps 1/8 inch wide) straight up the middle to create the black line of separation between the red stripes. Remember everything UNDER the tape STAYS black when you remove the tape. Paint it red, keeping each coat of paint thin but using multiple coats. This prevents edge buildup (from real thick coats) when you remove the tape. Let it dry. Slowly remove the masking tape. Top coat with satin finish clear (or gloss, your choice) and let 'em dry.
Easier than it sounds, really.
Looks good. A touch of body color on the caps ties everything together IMO.
Heres what i followed, basically what GaryaHouse said: These are the products the guys used. I used bacically the same,but different brands
First you have to disassemble the caps. There are 4 tabs on the back.
Then I taped off around the rhombus with painters tape.
I sanded the silver parts with 800 grit automotive sandpaper on a palm sander.
Cleaned everything up with 91% isopropyl alcohol.
Wiped it down with the 3m adhesion promoter pads or adhesion spray.
Sprayed 5 thin coats of the Tor red paint 10 minutes between coats.
Sprayed 5 thin coats of the high gloss clear coat 10 minutes between coats.
Let dry for at least 3 hours.
Reassembled.
Products used:
Matte black center caps
DODGE CHALLENGER CHARGER Matte Black Chrome Stripe Wheel Center Cap Set Of 4 OEM https://www.amazon.com/dp/B06X9BTTM9/ref=cm_sw_r_cp_apap_Ze2z1Viyysptt
Adhesion promoter Pads or a spray
3M 4298 Adhesion Promoter, Sponge Applicator 5 Pack (5) https://www.amazon.com/dp/B01G2BHLG6/ref=cm_sw_r_cp_apap_LiSz2Odi6Notx
Mopar Tor red pqd spray paint
Dodge Touch Up Paint | AutomotiveTouchup
High gloss clear coat
USC SprayMax 2K Glamour High Gloss Aerosol Clear https://www.amazon.com/dp/B0082LJMC6/ref=cm_sw_r_cp_apap_wonUoqdya4lNg
Reactions: Squirrel392
