1 - 3 of 3 Posts
Anyone know which fuse covers the passenger side 12V outlet on the 15+ cars? Mine is dead and I cant seem to find it on the fuse diagram I have.
IGN. It's in the rear under the trunk cover by the battery, should be the fuse closest to battery and far right, 20 amp. You can move the fuse up one position forward to put the legs in the next set of slots B+ and will go from ignition only to constant 12V.
The front integrated center stack power outlet can be changed from switched “ignition” to constant “battery” powered all the time by moving the integrated center stack fuse #12 in the Rear Power Distribution Center from fuse location “IGN” to “B+.” Refer to “Rear Power Distribution Center (Fuses)” in “Maintaining Your Vehicle.”
Reactions: 762x51
1 - 3 of 3 Posts
