Hello all,
2010 R/T Classic.
My window was doing the up/down by itself thing and draining my battery. I've researched that the most likely culprit is the passenger door latch and I ordered the part. Here is my question: what does the bottom electrical plug on the latch itself do? If I unplug that... the window doesn't act possessed and my battery doesn't drain... but all of the window functions still work properly including the window drop when you open the door and raise when you close it, the locks and window controls from both sides of the car. All switches still work. When I unplug the top connection... no window functions work however the window still does it's acting up thing. I'm confused. What does that plug/switch actually do? Photos attached. The connection and switch in question is the bottom white one.
Thank you,
Shane
Wood Gas Auto part Metal Automotive tire
Gas Motor vehicle Automotive exterior Asphalt Vehicle door
Motor vehicle Automotive tire Electrical wiring Automotive exterior Vehicle door
Plum 2019 SXT AWD
Depends. Cannot really tell what that is hooked up to. I am guessing one of those is the CAN bus. With that unplugged, nothing should work, like you are seeing. Here are a couple of prints from the Chilton Manual.
Rectangle Slope Font Parallel Engineering
Well that's the thing. Everything still works. My fingers are holding the wires that run to that plug, but it's all wrapped. I don't know what those specific wires connect to without digging in.
Vehicle Motor vehicle Hood Automotive lighting Automotive tire
· Super Moderator
Plum 2019 SXT AWD
In all honesty, I am still confused. I can tell each of your plugs have a wire with orange on them, but nothing on the print shows two, two pin connectors. Best guess is those are the two wires that talk to the door control module.
· Super Moderator
I believe it's just the 2 pin connector I posted. I don't see 4 pins in his picture
