Hello all,
2010 R/T Classic.
My window was doing the up/down by itself thing and draining my battery. I've researched that the most likely culprit is the passenger door latch and I ordered the part. Here is my question: what does the bottom electrical plug on the latch itself do? If I unplug that... the window doesn't act possessed and my battery doesn't drain... but all of the window functions still work properly including the window drop when you open the door and raise when you close it, the locks and window controls from both sides of the car. All switches still work. When I unplug the top connection... no window functions work however the window still does it's acting up thing. I'm confused. What does that plug/switch actually do? Photos attached. The connection and switch in question is the bottom white one.
Thank you,
Shane
2010 R/T Classic.
Thank you,
Shane
