1MV641DVAA but it might supercede to another number .
I hope it's held in by clips. I was going to remove the door panle but I'll just wait until the part come in to see how it should go in...I can't tell from the drawing if the switch bezel is separate, but I would say probably. As for removing the old one, I'm sure it's held on by clips. Just pull up gently and it should come off.
I've actually removed that door panel before when I replaced the glass. Pretty straightforward. Thanks!I just looked at the repair manual and it looks like you may have to remove the door panel. I have the instructions if you need guidance.
