Not sure if this has been asked before, but I’m looking for a phone holder for my 2015 challenger, it’s a six speed so not sure the cup holder one will work with shifting and all. I don’t want to glue/stick anything to the car. I’m probably out of luck on this one, but was wondering what do y’all do for phone holders. Thanks in advance for any ideas.
I recently inquired about this about 6 weeks back I think and after reading several forum posts ended up using the following combo of using a combination of PanaVise Dash Mount Plate with a Pro-Clip holder.
PANAVISE
PRO-CLIP
I like the rotation, movement, and tilt range of this phone mount from Pro-Clip attached to this mount.
The year range for the Challenger goes up to 2014 so you might want to reach out and verify it's still good on the later models
Large Universal Adjustable ProClip Holder T3 - This Large Adjustable Universal Holder is designed to hold devices used without or with a skin or case. You make a one time easy adjustment to have.
www.proclipusa.com
Here are some images of my setup in my Magnum (Daily Driver).
You have several mount choices up/down along this panel area based on the mounting screws for your radio.
I like that it's very secure and the plate is firmly attached with existing mounting screws.
Some people do not like that this causes a slight buckling of the trim alongside it.
I've read postings where someone had this installed for over a year and when uninstalled, looked like it returned back to normal.
Let us know what you end up going with and pics if possible to help others as well.
