1 - 4 of 4 Posts
Installed my her short throw shifter and everything seemed to go fine now that its all buttoned up I can't get into 2nd 4th or 6th gear even neutral pops really bad when I roll there's some sort of binding happening please any advice would be greatly appreciated
What he said, make sure you tightened the bolt that goes to the shaft on the bottom of the shifter, I used lock tight on mine to keep it in there, also make sure the two snap pins are still in on the ends of the shifter. I suspect that one of these areas is where your problem lies. Good luck and post back your findings if you find something.
make sure shift handle is on right side of the block, check the lower rubber boot isn't binding up or that you have too much dynomat on the shifter preventing it from actually moving.
1 - 4 of 4 Posts
