I didn't realize how simple some of the available Plug and Play LED lights are for the front end until I watched this video.
The YouTuber points out that the brand he received may not be the best option as it had some fitment issues.
I was wondering what the best options available are for switching out the Halogens on the front with LEDs.
I know of Xenon's and a couple other brands.
Basically the best options for plug and play sets for the headlights, the turn signals, and the fog lights.
I can't afford switching to HID right now but I will remember that option for the future.
Any help appreciated.
Everything needed for the conversion, yes. There are ballasts that you mount externally. A Guy
Im confused, so what type of bulbs do we have? HID or LED?
I just want to replace my fog light bulbs with the same color and intensity as my headlight bulbs. Any idea what info I would need for this?
It was easy. Make sure to get the headlight bulbs with the canbus adapter on them. Pop the caps off and swap the bulbs tuck the adapter inside the headlight and close the cap. I did both Headlight and fog light and they match great. I have two different brand but the colors are dead on. I will take a pic once I go down stairs. Make sure when you put the fog Bulb in it sits all the way. Otherwise you will get uneven brightness from water but it is an easy fix.
