81 - 100 of 294 Posts
4.44 was my best last year on D/R's. I have more HP now so wheel spin is a real problem. But I am going to a 9" Ford IRS So I am sure I can shave some wheel spin/time off my personal best. 70
4.64 with traction control on.
traction control off. must be right because the computer tells me so right!!!
this is why I say the computer times are total BS.
I could of got a 1.5 if I wanted to try harder.
For a true calculation of timed acceleration runs Chrysler should have found a way to get the speed sensor reading for the EVIC from the front tire. Sensors reading from the tranny or rear wheels are greatly affected by wheel spin.
Rob
agreed. I think the only one that works halfway decent is the braking one.
The timer said I was doing 60 and my car was barely moving because I was doing a burnout. people who think their 0-60 times are accurate are sadly mistaking.
again, take your car to the track and get a 1/4 or 1/8 mile run to see what your car can do not these BS times.
Ok here are my best times...
On all runs I also had my G-Timer GT2 running as back up so I will post both times...
2008 Charger SRT8 Auto
Mopar CAI
Mopar Cat-Back
Predator 93 Tune
Temp 69
Sealevel
Asphalt (10:15 AM)
EVIC 0-60 4.59
G-Tech 0-60 4.7
Most tests by the press had them at 4.8-5.0
2009 Challenger SRT8 6 Speed
Mopar CAI
Mopar Cat-Back
Mopar Strut Tower Brace
Mopar F/R Sway Bars
Mopar KW Adjustable Coil-Overs
85mm TB
Predator 93 Tune
Temp 67
Sealevel
Asphalt (11:30 AM)
EVIC 0-60 4.69
G-Timer 0-60 4.76
Most test by the press had them at 4.6-4.9
2011 Challenger R/T Classic Auto
K&N Drop-In Air Filter
Never Tested
Most test by the press have them at 5.0-5.5
This is from MotorTrend:
When we first tested the Challenger R/T, we recorded a 0-60 time of 5.1 seconds. For 2011 that number drops to 5 seconds flat. In the quarter mile the old car banged off a 13.6 second run at 104.9 mph compared to the new car's run of 13.5 seconds at 105.9 mph.
2012 Challenger SRT8 Auto
100% Stock
Temp 69
Sealevel
Asphalt (5:30 PM)
EVIC 0-60 4.46
G-Timer 0-60 4.42
Most test from the press have them at 4.4-4.6
This is from Edmunds test of the 2011 Challenger SRT8 Auto:
At the test track the Challenger lays down some impressive numbers. The 0-60-mph sprint comes in 4.5 seconds from a standstill, while the quarter-mile passes in 12.6 seconds at 112.1 mph. That's scary quick by any measure. Notably, the engine is smooth and refined even when pressed hard, giving it an easygoing no-sweat sort of personality that's easy to like.
My goal when she is broken in with a K&N drop-in is 4.3-4.5
Decided to play with my 0-60 on the way home from the market. 4.78 with the only mod being an Arrington CAI. Can't wait to get that a little lower.
On all runs I also had my G-Tech pro running as back up so I will post both times...
Mopar CAI
Mopar Cat-Back
Predator 93 Tune
Temp 69
Sealevel
Asphalt (10:15 AM)
EVIC 0-60 4.59
G-Tech 0-60 4.7
Mopar CAI
Mopar Cat-Back
Mopar F/R Sway Bars
85mm TB
Predator 93 Tune
Temp 67
Sealevel
Asphalt (11:30 AM)
EVIC 0-60 4.69
G-Tech 0-60 4.76
Never Tested
100% Stock
Have not tested yet, only 130 miles on her...
EVIC 0-60 TBD
G-Tech 0-60 TBD
if your 12.6 is from a run at a track post up a time slip so I can add you to the 392 and top 50 list.
Dadstoy... I think cortc was quoting an Edmunds test on the 12.6 time....
OK thanks, don't want to miss anyones real times.
0-60 time
Did this the other day and had 3.50. It was around 49 degrees, I have
the Arrington 426/maggie with SHR trans, but have stock tires and stock
peg leg 3.06 rearend. I used autostick, had to baby it and never went
WOT but have no doubt with LSD and better tires I could lower that
alot.
Ok here we go...
F1 tires at stock pressure, 645 miles on the odometer it was 69 F and the asphalt temp was about 72 F @ sea level (Miami, FL)...
First attempt the rear came lose even with TC on and the time was 4.78
Second attempt with TC still on and rolling into the throttle a little less aggressive, she spun then hooked up for a 4.46. (G-Timer said 4.42…) Did not really try hard so I know there is a 4.3 in her and if conditions are right I am pretty sure she could do a 4.26-4.28, will try again when I get a chance. (These cars are impressive and definitely underrated, 4260 pounds and pulling low 4 second 0-60 times...)
The issue is not power it is hooking up / traction, I would not be surprised to see close to 4.0 flat with sticky tires and dropping the pressure...
When I first got mine it was 90 degrees at night and the best I could pull was about 5.4. After CAI I was at 5.2, still hot outside.
After the temps dropped into the 40-50 range and I added the other mods in my sig I've dropped to 4.76 with no spinning.
At this point with TC on I really have to be gentle with the throttle or I will spin for 10-20 feet.
What tires?
What tires?
Sorry, Firehawk GT 20".
I've been shopping, thinking of changing my wheels and going 10" wide on the back with 275's and switching to Nittos but it is my DD so I don't want 5-10k mile tires...
