LUV MY RT asked me to post this for him since I'm on the forum a lot more than he is.
LUV MY RT from the forum and I are good friends. He's local and we go to the track together. Those of you at ChallengerFest last year will remember him and his wife having the black R/T with the Vortech supercharger.
Last Saturday we went to Beech Bend to run a few passes.
We both slapped on our M&H DRs and he's first to go down the track. He ran a personal best of 12.42 at 110.64. He's got the Vortech setup on his 09' Challenger R/T Auto and was running stock Vortech boost which I believe is 6.5psi and he's running the the Boost A Pump. The temps at the track were in the high 60s and he was running high octane Sunoco fuel. The car was custom tuned, but I'll let him go in to that if he wants.
I didn't see him pull back around after his run so I go to our pit area to check on him. He's sitting in the car with it idling and tells me it feels like it has a miss. I listen to the exhaust and it sounds OK, but the engine was jumping around like he had a big lopey cam in it. NO check engine lights though. Weird.
I figure he's spun the crank pulley and gotten something off balance. We give GSO a call for a 2nd opinion and he asks a few questions and says it might be a broken motor mount since there were no CELs.
The car gets him 120 miles home....still no CEL, but its running pretty rough by the time he gets in the driveway. No smoke or anything outta the exhaust.
He pulls all the plugs and finds one of the plugs in cyl 7 has a bent electrode. The plugs in cyl 1 are fouled. The rest of the plugs look good.
He does a compression check and starts with cyl 7 since it had the bent electrode plug. It reads fine. He calls me and we think he's dodged a bullet. He goes ahead and checks the compression on the rest of the cylinders just to be sure and finds the compression in cyl 1 is way way low.
Crap! He does a wet compression check to see if it's a piston or a valve....turns out it's a piston as when he added a bit of oil to the cylinder the compression came right up.
He's looking at options now and will be coming up with a plan to get back up and running. We're hoping he can still make ChallengerFest2 but things aren't looking good at this point.
I'm sure Greg will post in to this thread when he has time to get on the computer, but he wanted me to give you guys a heads up.
