1 - 4 of 4 Posts
Hi Guys,
I have 3 connectors under the power box that have corrosion on them and broken pins.
I suggest you watch this area for splashing or car wash overspray getting in under this box resulting in a very expensive repair/replacement.
Tech suggested a waterproof tape, but I'm going to cover the underside in plastic to try and keep moisture out in the future.
Found a guy on YouTube that does TIPM box repair/replace but waiting to find out about new connectors.
Any ideas help would be appreciated....
Rob
Once you have gotten rid of ALL of the corrosion, seal everything with RTV. That is how all of the electrical/electronics on aircraft is protected, and it's easy and inexpensive.
applying dielectric grease on the connectors is a good idea as well. It will insulate against exposure to air / moisture to preclude corrosion.
I found out the DIELECTRIC GREASE is nothing more than Vaseline.
1 - 4 of 4 Posts
