POWERSTOP TRACK DAY PLUS BRAKE KIT 2015-2018 392/6.4L/6.2L CHALLENGER/CHARGER W/ 6 PISTON BREMBO BRAKES
-Chris
To Order: Powerstop Track Day Plus Brake Kit 2015-2018 392/6.4L/6.2L Challenger/Charger w/ 6 Piston Brembo BrakesAs a weekend enthusiast, you demand much of your brakes. Power Stop Track Day Plus brake kits are your high performance solution and they are platform-specific. When racing temperatures rise and driving is more aggressive, Power Stop R&D PST pads have a new friction compound that features extreme fade resistance at high temperatures, low thermal conductivity, and consistent pedal feel and modulation. The kits combine these pads with a matched set of high-carbon drilled and slotted rotors for longer life, better braking stability, and confident driving. Together, they are the ideal platform-driven brake kits to take you to the track and back home safely. If you want to optimize your visits to the track, let Power Stop equip you with the perfect friction combo for a winning weekend--Track Day Plus brake kits--they're track-tested and platform-approved!
Rotor Specifications FRONT REAR
Bolt Circle (in) 4.5 4.5
Bolt Circle (mm) 115.0 115.0
Diameter (in) 15.3 13.8
Diameter (mm) 390 350
Height (in) 2.0 2.7
Height (mm) 50 68
Hub Hole Diameter (in) 2.9 2.8
Hub Hole Diameter (mm) 73 72
Minimum Thickness (in) 1.2 1.0
Minimum Thickness (mm) 31.0 26.0
Nominal Thickness (in) 1.3 1.1
Nominal Thickness (mm) 34.0 28.0
# of Holes OR Studs 5 5
Rotor Construction Floating Rotor Floating Rotor
Solid / Vented VENTED VENTED
Stud / Stud Hole Size 16.6 16.7
-Chris
