I know alot of you guys use predators so this is an easy question. I put a tune in my car for the first time yesterday and this morning the battery was dead and I had to put the charger on a while before I could start it. Did I just not run the car long enough after the flash or is there something in the flashes that will continue to drain the battery.
Thanks for any inputs.
Nothing you did with the predator caused your battery to be dead. Something else is draining it, like a cabin light left one, parking lights, etc.
Thanks I thought I had everything off durring the flash and only started it up for a second afterwards and then got out of the car. It's never even turned over slow even after setting for 4 days straight before.
Ok that's good. I'm going to be doing this myself as soon as I empty a full tank of 89, I'll be sure to drive the car around a good bit after.
Ya it about killed me letting this predator box set here all week knowing I had my CAI in place and I needed to run a second tank of 93 thru before tunning.
