When you load up a Predator canned tune, are you required to manually put in the tire size dimensions, or does the Predator default/assume you are running 20 inch rims with OEM tires? When I looked at the options, everything was blank.
If I remember right the tire size is in a differant part than the performance tune is and that perameter isn't changed by putting in a canned tune. You can always go to their site and ask if no one on here knows for sure. They are good about answering email questions.
Yeah you dont need to worry about the tire size, unless you run a different size tire.
Discussion Starter · #4 ·
Okay, thanks. I figured as much, but wanted to check. However, with this 93 CAI tune, my tires are getting smaller by the day as is my MPG. :)
