1 - 20 of 51 Posts
Installed the predator yesterday with 91 cai, nice improvement but tried to use quick adjust parameters for esp, tcm, shiftpoints, shift firmness and they were not available. called Diablo and they said these were not supported on a 09 R/T. told me to check every month for an update.
like getting a great toy for Christmas but no batteries!
just have to sit on it for a while.:(..:bigthumb::bigthumb::bigthumb:
09 R/T automatic.
see last post for my happy news:guiness:
Yes the tunes work but the special "Quick Adjust parameters" do not support the 09 R/T.
don't get this wrong the boxed tunes are there an d the one i loaded is great, there are other parmaeters that the predator updates/changes (listed in original post) that are not supported at this time for the 09 R/T. like i'm halfway home, closer but not there. i was told to check every month for a predator update. who knows when that will happen.
I adjusted the transmission shift firmness on my 09 R/T (which I don't have anymore). I don't know if I accessed it via Quick adjust or not... I do know I tried it on my 2010 R/T classic, I think through Quick adjust and it said it wasn't supported. I thought it odd, but haven't looked into it any further yet.
Mike
Yah I"ve known about that for a year and have been trying to let people know but I keep getting my head shoved under water by the supporters.
Same old song and dance about keep checking for updates. When I discovered it I think it was software 17 now their at somethng like software 27 :dunno:
Question - does a Trinity allow those parameters to be adjusted on a 2009? I thought the 2010 year had more issues than the 2009s because of a re-designed ECU- we didn't get the skip shift feature added until a few months ago
Why do they not tell you upfront so the frustration factor is not there. i still would have invested in the predator but would not have been PO'd.
i would like a better answer from Diablo than check monthly, are they working on it or not? 1 month 3months 6months or never!
I sure know what your talking about... I bought a Diablo Predator at the '08 SEMA show for my '09 R/T after the sales guy told me all the fantastic things it did... Forgot to tell me the important part: The tune wasn't available yet but they were working on it. Had to wait almost 6 months to get something usable in my car, and then the first few versions sucked.
Had practically the same issue with my Shelby. Tune didn't work right (throttle hung when coming to a stop) that took a 2nd party tuner to finally figure out. When they finally do get it, it's great, it just takes awhile. I'd still buy from them again.
Discussion Starter #12
Diablosport, any comment ??
I guess i have 30 days to return if i'm not happy with it, am i too demanding?
you look at the grid! 09 is predator 7135.
no disclaimers!
i would like Diablo to tell me and the other09 R/T owners when they expect to do the update.
Diablomike are you able to shed some light on this. please PM me.
U7135 Stock Vehicle Tunes:
5.7 HEMI 20 rwhp 20-25 ft/lbs
6.1 HEMI 20-25 rwhp 20-25 ft/lbs
93 Octane Performance Tune
91 Octane Performance Tune
93 Octane Performance CAI Tune
91 Octane Performance CAI Tune
Modify Factory Tune
U7135 Specific Features:
Click here to see more details on how to adjust parameters.
Axle Ratio
Idle RPM Drive/Neutral
WOT Fuel 1k-3.8k / 4k-5k / 5k-7k
Rev Limit Drive/Neutral
WOT Spark 1k-3.8k / 4k-5k / 5k-7k
Cooling Fan adjustment
Tire Size
Shift Points(preset values)(05-07 models ONLY)
Shift firmness(preset values)(5.7L HEMI models ONLY)
Autostick auto upshift enable/disable(05-07 models ONLY)
ESP enable/disable
MDS enable/disable
TCM adaptive reset
Speed limit
Read/Write time is approx 60 seconds
Clear codes supported
Multiple custom tunes.
All standard DiabloSport Predator features
iam pretty sure that all of these adjustments can be made with my 09 RT and the predator.
Discussion Starter #18 (Edited)
not, the quick adjustment parameters, ie esp mode,reset tcm adaptation, shift points, shift firmness, autostick auto upshift, are not supported for the 09 auto, i called Diablo and they confirmed that these are not available....
Vtodd, Please check out as I'm v.9r27 and it is not available and called Diablo and they confirmed that>
Discussion Starter #19
Too fart, please pm me with your Father in law info as Diablo confirms that its not available.
I just tried it on my 2010 R/T (auto). You are correct, I could not adjust it through "quick adjust". However, I was able to adjust the transmission shifting firmness through the modify tune menu. You can do this even if the tune is already loaded in the PCM.
Plug in pred,
select Diablo tunes,
select the tune that is currently loaded (in my case, 93 CAI),
select modify tune,
then, I think, adjust parameters,
then transmission,
and finally transmission shift firmness
Once you increase shift firmness, it will change it in the PCM, you don't have to reload the whole tune again.
Shift point adjustment is not supported for 09 and above 5.7's... just shift firmness. Not sure about the other items you asked about.
Oh, and Im on v.23
I did it this same way on my 09 R/T auto last year.
Hope it helps
Mike
1 - 20 of 51 Posts
