1 - 4 of 4 Posts
if im switching from the 91 tune to the 93 tune do i have to go back to stock first or can i switch between the two...also is there a big difference between them?????
You lijkely won't notice a difference. You don't need to go to stock, you just need to make sure you're running 93 fuel.
I recently went back to my stock tune and just changed a few things around, optimized it for the 87 fuel I get here doing some data logging. With the throttle sensitivity setting in the latest release feels that same as when I was running the 91 tune (So Cal = no 93 gas).
I don't know what the difference would be if any on a dyno, but I am also just speeding to and from work, so I don't particularly care about number. It just needs to feel right.
if you are going to run the 93 tune you need to run 93 octane gas.
most of the time for the raod I ran the 89 tune and it performed pretty good for the street.
I was running the 93 tune but it started tripping the knock sensor over the winter. Switched to the 91 tune with 93 octane gas. I think it might actually be running better on the 91 tune.
1 - 4 of 4 Posts
