I got a bone stock 09 r/t 6 speed and I can buy a predator u7135 and was wondering if I will still need a pedal commander or will it help with the lag and how easy is it to use and what can I expect from it thanks
I think the predator has throttle booster which you can adjust by percentage. This essentially makes the pedal more sensitive but not sure how it compares to the pedal commander?
There is a throttle boost option in the programs. I set mine to the max of 20%. It takes away that damned dead spot.
2014 SRT Core
Yep what the others said, I'd try the Predators throttle boost option and see if that fixes things for you. It's one of the options I used when I had my R/T and ran the Predator.
