1 - 1 of 1 Posts
On the serious side, I have a mini shift light and was wondering what it takes to install it next to the tachometer on the right hand side? How do install the clip for the light? I would imagine that you have to "drill" a small hole and attach it with a small screw but what is on the other side as far as wires go, any one know? I don't think that the two way tape is the way to go also, what do you do with the slack in the wire that would be required, if you want to remove it to re-adjust the settings of the unit itself? would that also require a hole in the same area?
Thanks, David
1 - 1 of 1 Posts
