I have a 2010 SRT8 and I am planning on purchasing a ProCharger in the next couple of months. I'm probably gonna go with the Stage 2 intercooled with a D-1SC head unit. I want to make sure I have everything that I need before I ever install the ProCharger. Everybody with any advice feel free to chime in- I'd appreciate all the help I can get. Also, let me know the best places to buy from.
the kit should come with everything you'll need additionally. you already have the catch can and tuner so that's a plus.
When I purchased my Stage II kit, ProCharger did not offer the full kit when upgrading to the D-1SC, so if you buy the tuner kit, you would need to purchase fuel injectors, a tune, and BAP (if you want to run one).
Regardless if you get the full or tuner kit, you'll also need a 5% overdrive ATI harmonic damper, Part# 918432. If you decide to purchase a damper other than the 5%, keep in mind that it will change the boost levels of the kit. A larger damper will increase your boost, so if you have a stock motor you might want to be somewhat conservative.
Excluding the damper, here are some additional items I purchased:
1. Spark Plugs (NGK 2315) - These are 1 step colder on the 6.1L
2. ProCharger Oil Drain Kit (3PCOL-002) - This makes changing the SC oil soooo much easier
3. Fuel Line disconnect kit - You can get these separately, but I can't remember the size needed for our fuel rails.
4. Plastic rivets to re-attach front fascia. The kit does include some, but it's best to have extras. I bought a Rivet kit that comes with the handheld tool at Harbor Freight
5. Wideband O2 sensor
6. Boost sensor (The Trinity measures boost, so I don't use this often)
7. EGT sensor
8. Diablo Sport Trinity (I purchased the Trinity so I can data log AFR and EGTs along with other PIDs)
(I highly recommend you install and get your gauges working before installing your SC)
Here are the tools, other than a set of hand held tools, you're going to need:
1. Torque wrench
2. 3-jaw gear puller (to remove harmonic damper)
3. Damper install tool
4. Drill (to pin crank)
get the helical gears on the d1sc. $100 extra charge, really quiets it down some if that bothers you.
Great info-keep it coming though, you can't ever know "too much" about a mod. I'm planning on getting all the good out of the stock 6.1 motor and then I'm gonna go with a 426 short block. Also, do you need a blower cam with the ProCharger? Suggestions?
Depends on what you're trying to do. A d1sc on a 426 will not see more than 10-12psi
You don't "need" a cam with the ProCharger.
I would wait until you build the 426, especially if you're going to leave everything else stock. For the amount of boost you'll be running on the stock motor, I don't think it's worth the time, effort and money for the amount of HP gain.
