1 - 3 of 3 Posts
QA1 CARBON FIBER DRIVESHAFT 2015-2018 6.2L CHALLENGER SRT HELLCAT
These bolt-in REV™ Series carbon fiber driveshafts are designed and wound specifically for Challenger SRT Hellcats with up to 1500 HP and a max rated torque of 1000 lb*ft. They feature the same high quality materials and benefits as the rest of the REV™ Series driveshafts.
QA1's Challenger Hellcat driveshafts feature Spicer Life Series 1350 U-joints, and utilize a high speed CV joint with a high speed sealing boot and high temp grease. This high speed capability allows us to minimize effects of NVH while increasing performance. They also offer a 27% weight savings over stock two-piece driveshafts, while their 3.3" diameter tube provides better clearance for exhaust systems.
What makes QA1's driveshaft the best?
  • A truly engineered system from transmission to rear end
  • Extended transmission and differential life
  • Quicker acceleration
  • More power to the ground
  • NVH testing helps minimize driveline vibrations
  • Balanced as an assembly without the use of welded or bonded weights, ensuring a precise and more reliable balance
  • Lighter and stronger than steel, aluminum, and other carbon fiber driveshafts
  • Safer than steel and aluminum driveshafts
  • Proudly wound in-house using 3M™ Matrix Resin in QA1's Lakeville, Minnesota facility
To Order: QA1 Carbon Fiber Driveshaft 2015-2018 6.2L Challenger SRT Hellcat
Thanks
Chris
Dead thread revival- will these fit a Scat pack or 392?
1 - 3 of 3 Posts
