I have my 2014 R/T Plus. I have constantly been having issues with my quarter panel marker lights filling with water. Especially the driverside. The left side got so bad that the socket rusted and I had the dealer replace the socket. Now , I noticed the light bulb was out again and it was the same problem. This time I took a tiny drill bit and drilled two drainage holes in each marker light housing. Anyone else having this issue? The left side is able to work for now, but I can see that I will have the replace the socket again.
probably replace the side marker assembly - the seal between the outer lens and the housing might be bad.
I haven't heard of the issues of water getting inside, but that's probably what you have going on.
they clip in, so replacing them isn't difficult
I agree, not a common complaint so I suspect your side marker seals
They are made with a small black circle with a screen type material. I guess the factory knows that moisture must build up inside. The little vent screen didn't do its job. I went to auto Zone last night and bought some new bulbs and a replacement socket. Like they say.....if you want anything done right, you have to do it yourself.
