I have a picture taken on my rear brake discs. Is it normal for the brake pads to not work across the disc? Or maybe the wrong pads were used
Normal. Not sure why.I have a picture taken on my rear brake discs. Is it normal for the brake pads to not work across the disc? Or maybe the wrong pads were used
Thanks for the answer
Then I guess it changed in mid-year 2021, they have been using the short pad for a good while now.For 2021 you don't get slotted rotors on the 4 piston front/rear but it's a full sweep of the rotor.
View attachment 1078197 View attachment 1078198
Thanks for the official documentView attachment 1078288
Scat Pack rear brake issues ?
This is from a Charger forum & it looks like newer cars with 4-piston Brembos have pads that only sweep about 75% of the rotor's surface. Has anyone noticed this with newer Challengers? https://www.chargerforums.com/threads/scat-pack-rear-brake-issue.386056/ It appears new OEM replacement pads...www.challengertalk.com
