1 - 2 of 2 Posts
So i found a set of used ST coil overs with 30k miles for $300 and can't resist that deal so i plan to pick them up this weekend. My question is will I need a camber kit or any other parts when I install them? My main concern is tire wear, and i want to do anything to avoid excessive negative camber.
BTW they came off of a Magnum but the part number is 90281 which is the same as the ones for 09-10 challenger.
I would think that will depend on how low you set them.
The lower you go, the greater the negative camber.
Reactions: snowcat256
1 - 2 of 2 Posts
