I'm getting Flowmaster Super 44's installed on my 2014 v6 challenger this weekend. I also kind of want to get a resonator delete as well however I have heard this can be problematic in California.
Will I pass my smog in California if I have the resonators removed (I'm not touching the Cat Converters).
I understand that the resonators have nothing to do with emissions, however, I have heard that tampering with the resonators will make you fail your smog in California. \
If anyone could help me out that'd be great!
THANK YOU!
THANK YOU!
Your first problem is going with Flowmaster, instead go with Borla :)
As long as you don't touch the cats, you are good to go.
Reactions: Decheveria
Doesn't answer my question at all, or help me out in any way. I went with two stainless steel flowmaster super 44's for $90 each rather than 2 Borla mufflers for $153 each. I'm a student and those were too expensive.
Yes, no problem with that plan
As mentioned anything past the cats and you're fine. And if you know the right
person you're fine with anything before the cats too :wink3:
I would recommend that you have the Super 44's installed before removing the resonators. After you swap your mufflers out, drive the car for a while and see how you like it. If it is still not loud enough for you, bring it back in and have the resonators removed.
